axStart: Speed up your Microsoft Hyper V (Azure)
Источник: http://www.axstart.com/speed-up-your...hyper-v-azure/
============== The Hyper V these days from MS are getting bigger and slower. But what makes it slow. I can give you some tricks that will speed up the system. Let’s start have a look at the tasks: ![]() It is SharePoint that is killing us. Why SharePoint and especially the Search crawler. You start your Virtual machine. All services start and SharePoint looks at the timestamp of the search Database. And oh my god, it is 2 weeks old (last time you used that environment). Hurry, hurry start crawling, no time to waste, we have to correct 2 weeks. But 2 weeks for what… nothing has changed. So: Remove SharePoint Search, It will consume a lot of SQL power.
![]() Set Max Memory of SQL correct , 2048 will do the job ![]() Finally remove all retail components in case you don’t need them. With these settings you are able to run Azure on A5 Or just take some time, create a new window 2012 azure VM and install:
