axStart: Violation of PRIMARY KEY constraint ‘PK_ModelElementData_ElementHandle’ with AX 2012R2 CU8
Источник: http://www.axstart.com/violation-of-...ax-2012r2-cu8/
============== Last week, I was upgrading AX 2012 R2 CU7 to CU8 and ran into a model store error. The error was similar to http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx It scared the hell out of me! First thing that came to mind was: is my model store corrupt in production? But the source of the problem was indeed different; found out that the issue was label files. In the AX 2012 R2 CU7, the DMF labels were missing, so this was fixed by adding them manually (see picture below) ![]() This means that my AX2012 R2CU7 model store was consistent. Label files cannot be deleted directly from the AOT. In such cases, the following workaround is necessary:
