emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 6
Источник: http://blogs.msdn.com/b/axsupport/ar...ts-page-6.aspx
============== This is page 6 of 8 of the general performance analysis scripts online for the Performance Analyser 1.20 tool. See page 1 for the introduction. Use the links in the table below to navigate between pages. - General analysisAnalyse SQL ConfigurationPage 1Analyse SQL IndexesPage 2Analyse SQL QueriesPage 3Analyse BlockingPage 4Baseline - benchmark queriesPage 5- AX SpecificAnalyse AX ConfigurationPage 6Analyse AX IndexesPage 7Analyse AX QueriesPage 8Analyse AX Configuration AOS_DEBUG CONNECTION_CONTEXT TOO_BIG_FOR_ENTIRE_TABLE_CACHE TABLES_THAT_COULD_BE_ENTIRE_TABLE_CACHE ENTIRE_TABLE_CACHE_WITH_UPDATES OCC_DISABLED AX_DATABASE_LOGGING AX_ALERTS_ON_TABLE AX_BATCH_CONFIGURATION AOS_CLUSTER_CONFIG AX_DB_LOGGING_BY_TABLE NUMBER_SEQUENCE_USAGE USE DynamicsPerf --AOS Configuration issues -- -- AOS_DEBUG -- -------------------------------------------------------------- -- Is Enable X++ Debug enabled on any AOS Servers. -- 20% decline in transactions processed on the AOS instances with this enabled ----------------------------------------------------------------- SELECT SERVER_NAME, AOS_INSTANCE_NAME, SETTING_NAME, SETTING_VALUE FROM AOS_REGISTRY WHERE IS_CONFIGURATION_ACTIVE = 'Y' AND SETTING_NAME = 'xppdebug' AND SETTING_VALUE '0' -- -------------------------------------------------------------- -- CONNECTION_CONTEXT -- Is Context_Info enabled on any AOS Servers. -- ----------------------------------------------------------------- SELECT SERVER_NAME, AOS_INSTANCE_NAME, SETTING_NAME, SETTING_VALUE FROM AOS_REGISTRY WHERE IS_CONFIGURATION_ACTIVE = 'Y' AND SETTING_NAME = 'connectioncontext' AND SETTING_VALUE '0' --AOT configuration issues -- TOO_BIG_FOR_ENTIRE_TABLE_CACHE -- -------------------------------------------------------------- -- Find tables that have entire table cache enabled that are larger than 128K -- Causes the cache to overflow to disk on the AOS Server ----------------------------------------------------------------- SELECT A.TABLE_NAME, APPLICATION_LAYER, CACHE_LOOKUP, PAGE_COUNT FROM AX_TABLE_DETAIL_CURR_VW A, INDEX_STATS_CURR_VW I WHERE A.DATABASE_NAME = I.DATABASE_NAME AND A.TABLE_NAME = I.TABLE_NAME AND CACHE_LOOKUP = 'EntireTable' AND ( INDEX_DESCRIPTION = 'HEAP' OR INDEX_DESCRIPTION LIKE 'CLUSTERED%' ) AND PAGE_COUNT > 16 -- 128kb --AND PAGE_COUNT> 4 --32KB AX2012RTM --AND PAGE_COUNT> 12 --96KB AX2012R2 ORDER BY PAGE_COUNT DESC -- TABLES_THAT_COULD_BE_ENTIRE_TABLE_CACHE -- -------------------------------------------------------------- -- Find tables that have no cache enabled that are smaller than 128K -- These could cause lots of roundtrips between AOS and SQL -- -- NOTE: -- Table should be static and not updated much before changing -- cache to Entiretable ----------------------------------------------------------------- SELECT A.TABLE_NAME, APPLICATION_LAYER, CACHE_LOOKUP, PAGE_COUNT FROM AX_TABLE_DETAIL_CURR_VW A, INDEX_STATS_CURR_VW I WHERE A.DATABASE_NAME = I.DATABASE_NAME AND A.TABLE_NAME = I.TABLE_NAME AND CACHE_LOOKUP = 'None' AND ( INDEX_DESCRIPTION = 'HEAP' OR INDEX_DESCRIPTION LIKE 'CLUSTERED%' ) AND PAGE_COUNT < 16 -- 128kb --AND PAGE_COUNT> 4 --32KB AX2012RTM --AND PAGE_COUNT> 12 --96KB AX2012R2 AND PAGE_COUNT > 0 ORDER BY TABLE_NAME DESC -- -- ENTIRE_TABLE_CACHE_WITH_UPDATES -- -- -------------------------------------------------------------- -- Find tables that have entire table cache and show update rate -- Causes the cache to be refreshed on all AOS instances ----------------------------------------------------------------- SELECT A.TABLE_NAME, APPLICATION_LAYER, CACHE_LOOKUP, USER_UPDATES FROM AX_TABLE_DETAIL_CURR_VW A, INDEX_STATS_CURR_VW I WHERE A.DATABASE_NAME = I.DATABASE_NAME AND A.TABLE_NAME = I.TABLE_NAME AND CACHE_LOOKUP = 'EntireTable' AND ( INDEX_DESCRIPTION = 'HEAP' OR INDEX_DESCRIPTION LIKE 'CLUSTERED%' ) ORDER BY USER_UPDATES DESC -- -- OCC_DISABLED -- -- -------------------------------------------------------------- -- Find tables above SYS layer that do not have OCC enabled: -- ----------------------------------------------------------------- SELECT TABLE_NAME FROM AX_TABLE_DETAIL_CURR_VW WHERE APPLICATION_LAYER NOT IN ( 'SYS', 'System Table' ) AND OCC_ENABLED = 0 ORDER BY TABLE_NAME -- -- AX_DATABASE_LOGGING -- -- -------------------------------------------------------------- -- Find tables above SYS layer that have logging enabled -- ----------------------------------------------------------------- SELECT * FROM AX_TABLE_DETAIL_CURR_VW WHERE APPLICATION_LAYER NOT IN ( 'SYS', 'System Table' ) AND ( DATABASELOG_INSERT = 1 OR DATABASELOG_DELETE = 1 OR DATABASELOG_UPDATE = 1 OR DATABASELOG_RENAME_KEY = 1 ) ORDER BY TABLE_NAME -- -- AX_ALERTS_ON_TABLE -- -- -------------------------------------------------------------- -- Find tables above SYS layer that have events enabled -- ----------------------------------------------------------------- SELECT * FROM AX_TABLE_DETAIL_CURR_VW WHERE APPLICATION_LAYER NOT IN ( 'SYS', 'System Table' ) AND ( EVENT_INSERT = 1 OR EVENT_DELETE = 1 OR EVENT_UPDATE = 1 OR EVENT_RENAME_KEY = 1 ) ORDER BY TABLE_NAME -- SELECT * FROM EVENTRULE -- DO THIS IN THE AX DATABASE TO DISCOVER ABOVE DATA --AX Application configuration issues -- -- AX_BATCH_CONFIGURATION -- -- ----------------------------------------------------------------------------- -- List BATCHGROUP configuration in Dynamics AX -------------------------------------------------------------------------------- SELECT * FROM AX_BATCH_CONFIGURATION_VW -- -- AOS_CLUSTER_CONFIG -- -- ----------------------------------------------------------------------------- -- List AOS cluster configuration in Dynamics AX -------------------------------------------------------------------------------- SELECT * FROM AX_SERVER_CONFIGURATION_VW -- -- AX_DB_LOGGING_BY_TABLE -- -- -------------------------------------------------------------- -- List top 200 tables be logged in Dynamics AX -- NOTE: if this query returns zero rows -- the AOTEXPORT class has not been run ----------------------------------------------------------------- SELECT [TABLE_NAME], [ROWS_LOGGED], [DATABASELOG_UPDATE], [DATABASELOG_DELETE], [DATABASELOG_INSERT] FROM [AX_DATABASELOGGING_VW] ORDER BY [ROWS_LOGGED] DESC -- -- NUMBER_SEQUENCE_USAGE -- -- ----------------------------------------------------------------------------- -- List NUMBERSEQUENCE table configuration in Dynamics AX -- Are sequences marked as Coninuous? If so why? -- Is FETCHAHEADQTY > 0, if not preallocation is not setup for this sequence -- Pre-allocation requires knowledge of the avg. number of numbers consumed -- per user process to determine a good value. -------------------------------------------------------------------------------- SELECT RUN2.[DATABASE_NAME], RUN2.[COMPANYID], RUN2.[NUMBERSEQUENCE], RUN2.[TEXT], Datediff(hh, RUN1.STATS_TIME, RUN2.STATS_TIME) AS ELAPSED_HOURS, RUN2.NEXTREC - RUN1.NEXTREC AS TOTAL_NUMBERS_CONSUMED, ( RUN2.NEXTREC - RUN1.NEXTREC ) / ( Datediff(hh, RUN1.STATS_TIME, RUN2.STATS_TIME) ) AS HOURLY_CONSUMPTION_RATE, RUN2.HIGHEST - RUN2.NEXTREC AS [NUMBERSREMAINING], RUN2.[CONTINUOUS], RUN2.[FETCHAHEAD], RUN2.[FETCHAHEADQTY] FROM AX_NUM_SEQUENCES_VW RUN1 INNER JOIN AX_NUM_SEQUENCES_VW RUN2 ON RUN1.NUMBERSEQUENCE = RUN2.NUMBERSEQUENCE AND RUN1.COMPANYID = RUN2.COMPANYID WHERE RUN1.RUN_NAME = 'BASE_to_compare_to' AND RUN2.RUN_NAME = 'Feb_26_2020_804AM' ORDER BY 6 DESC --To find run_name run the following query SELECT * FROM STATS_COLLECTION_SUMMARY ORDER BY STATS_TIME DESC -- -------------------------------------------------------------- -- Review number sequence configuration in Dynamics AX ----------------------------------------------------------------- SELECT * FROM AX_NUM_SEQUENCES_CURR_VW WHERE CONTINUOUS = 'Yes' Источник: http://blogs.msdn.com/b/axsupport/ar...ts-page-6.aspx
