emeadaxsupport: How to deactivate security policy in AX 2012 RTM for a query only due to tuning performance
Источник: http://blogs.msdn.com/b/axsupport/ar...rformance.aspx
============== Here is an example on how to increase performance by temporarily deactivating a query used to show open vendor invoices: Open table Table VendTrans in AOT and expand methods and customize the method existsVendPaymReconciliationImport_SEBG() as follows: /// /// This source code is freeware and is provided on an "as is" basis without warranties of any kind, /// whether express or implied, including without limitation warranties that the code is free of defect, /// fit for a particular purpose or non-infringing. The entire risk as to the quality and performance of /// the code is with the end user. /// /// /// Determines if the VendPaymReconciliationImport_SEBG is being used as a return format on an open vendor invoice. /// /// /// True if the VendPaymReconciliationImport_SEBG is being used as a return format on an open vendor invoice. /// public static boolean existsVendPaymReconciliationImport_SEBG() { VendTrans vendTrans; VendTransOpen vendTransOpen; VendPaymModeTable vendPaymModeTable; boolean isFound; //MSFT Support - 2 lines added to bypass GAB security XDSServices xds = new XDSServices(); #DirParty //MSFT Support - 1 line added below, bypass GAB security. xds.setXDSContext(0, #InvalidContextString); select firstonly RecId from vendTransOpen exists join vendTrans where vendTrans.RecId == vendTransOpen.RefRecId exists join vendPaymModeTable where vendPaymModeTable.PaymMode == vendTrans.PaymMode && vendPaymModeTable.ClassIdReturn == classNum(VendPaymReconciliationImport_SEBG); // 1 line added below, revert back the security xds.setXDSContext(0, ''); isFound = (vendTransOpen.RecId != 0); return isFound; } Источник: http://blogs.msdn.com/b/axsupport/ar...rformance.aspx
