emeadaxsupport: Working with the message - System.ArgumentException: The endpoint associated with contract :HcmMassBenefitExpirationEngine is not found
Источник: http://blogs.msdn.com/b/axsupport/ar...not-found.aspx
============== I have seen a few instances with the following error: "System.ArgumentException: The endpoint associated with contract :HcmMassBenefitExpirationEngine is not found. at Microsoft.Dynamics.Ax.WCFDynamicProxy.DynamicProxyFactory.GetEndpoint(String contractName, String contractNamespace) at Microsoft.Dynamics.Ax.WCFDynamicProxy.DynamicProxyFactory.GetProxy(String contractName) at RunAsync(interpret* ip)" ![]() This error occurs when trying mass expire a benefit. The following steps will help you to allow this benefit to use the mass expiration functionality. 1. Click on AOT | Service Groups | HCMServices. Right Click on HCMServices and select Deploy Service Group ![]() 2. Once the deployment has completed, close the info log. ![]() 3. Click on AOT | Data Dictionary | Tables | AIFPortActionPolicy. Right click on the AIFPortActionPolicy Table and select Open. ![]() 4. We now need to create new record to enter the HCMMassBenefitExpirationEngineService.runExpirationProcess. Press Control + N on the keyboard to add a new line. In the Action ID field, select HCMMassBenefitExpirationEngineService.runExpirationProcess. In the Port field, select AxClient ![]() 5. Save the record and close the form. 6. Close the Developer Workspace. 7. Click System Administration | Setup | Services and Application Integration Framework | Inbound Ports. ![]() 8. Select HcmService and click Deactivate. Once the deactivation is complete, click Activate to re-activate the service. ![]() 9. Select AxClient and click Deactivate. Once the deactivation is complete, click Activate to re-activate the service. ![]() 10. Close the Inbound Ports form. 11. Click on Human Resources | Common | Benefits | Benefits. 12. Select the Benefit you wish to mass expire and click on Mass Benefit Expiration. ![]() 13. Click on Expire. ![]() As we can see, we were now able to mass expire the benefit. Thanks! Ryan S. Источник: http://blogs.msdn.com/b/axsupport/ar...not-found.aspx
