emeadaxsupport: Moving POS dlls from one machine to another causes the file to be blocked.
Источник: http://blogs.msdn.com/b/axsupport/ar...e-blocked.aspx
============== Description: After copying DLL files from another location, the POS is not loading the extensions because of the error:" This file came from another computer and might be blocked to help protect this computer" :) - The POS does not give any indication about the error as it does not try to load it. The Message is only shown when you right click on each file, in the general tab under the "Read-only and "Hidden" attributes. We ran into this problem when copying files to a POS computer for a customer via SkyDrive and the extensions files did not kick in. The error can only be seen on each file, not when you select all. Solution: When dll files are moved. Take the properties on the individual files and press the Unblock button Author: Kim Truelsen Date: 29/1- 2014 Источник: http://blogs.msdn.com/b/axsupport/ar...e-blocked.aspx
