kamalblogs: Producvity tip: Don’t scroll use Ctrl + G in your Editor – Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2013...r-dynamics-ax/
============== The other day as i was reviewing a code modification to a long method from my team mate he had to walk me up and down through the code scrolling. Just then the Ctrl + G flashed in me. Yes It takes a lot less effort to type in the line number then scrolling up and down. Even if you are not sure of the line number make it a guess then it is always a few lines up or down. ![]() If you are newbie here is how you can find the line number On AX 2009 You can identify the line number in the status bar. ![]() On AX 2012 Activate the toggle line number in the tool bar or identify the line number from the status bar ![]() Best practice Ideally keeping best practices in mind you must right methods that have limited number of lines and break them and keep it modular. ![]() Источник: http://kamalblogs.wordpress.com/2013...r-dynamics-ax/
