emeadaxsupport: Netherlands VAT report is displaying the old VAT rate '1a Belast met 19%'
Источник: http://blogs.msdn.com/b/axsupport/ar...st-met-19.aspx
============== Since October 1st 2012 the Netherlands VAT rate has changed from 19% to 21%. In order to update the NL VAT report in AX2009 & AX2012 to reflect this, the text on the VAT report needs to be changed from '1a Belast met 19%' to '1a Belast met 21%' for the Tax reporting code 110 Here is the procedure how to do this for Dynamics AX 2009 and AX 2012 AX 2009 1. Go to the AOT\Reports\TaxReport_NL 2. Locate the method ''makeReport' and on line 9 change the text '1a Belast met 19%'; to '1a Belast met 21% ![]() 3. Save AX 2012 1. Go to the AOT\Classes\TaxReportController_NL 2. On this class go to the method 'Fetch' 3. In here edit the label "@SYS310883'(rightclick on the label in the code and select lookup label/text) on line 20 for the language NL so that the label reflects the new VAT %. ![]() 4. Save Источник: http://blogs.msdn.com/b/axsupport/ar...st-met-19.aspx
