ax-erp: Try Catch and transactions
Источник: http://microsoft-dynamics-ax-erp.blo...nsactions.html
============== Hi all, Exception handling can be quite confusing in Dynamics AX, so I wanted to share some quick facts about try/catch and transactions. The general rule is that exceptions are caught in the outer most catch, where the ttslevel is 0. This means that if you put a transaction around a try/catch, your exceptions will not be caught. The following two jobs demonstrate that: Transaction inside try/catch: try { ttsBegin; throw error("an error"); ttsCommit; } catch { info("error caught"); } Output: Error an errorTry/catch inside transaction: ttsBegin; try { throw error("an error"); } catch { info("error caught"); } ttsCommit; Output: Error an errorAs you can see, the error is not caught when the transaction is around the try catch. However, there are two exceptions to this rule. The following code demonstrates that UpdateConflict and DupplicateKeyException can be caught inside a transaction. Set set = new Set(Types::Enum); // a set containing all possible exceptions SetEnumerator se; // enumerator used to loop though the set with exception Exception exception; // used to cast the value from the set boolean caughtInside; ; // add all exception to a set set.add(Exception::Break); set.add(Exception::CLRError); set.add(Exception::CodeAccessSecurity); set.add(Exception::DDEerror); set.add(Exception::Deadlock); set.add(Exception::DuplicateKeyException); set.add(Exception::DuplicateKeyExceptionNotRecovered); set.add(Exception::Error); set.add(Exception::Info); set.add(Exception::Internal); set.add(Exception::Numeric); set.add(Exception::PassClrObjectAcrossTiers); set.add(Exception::Sequence); set.add(Exception::Timeout); set.add(Exception::UpdateConflict); set.add(Exception::UpdateConflictNotRecovered); set.add(Exception::Warning); // create enumerator se = set.getEnumerator(); // loop all exceptions while(se.moveNext()) { // set flag false caughtInside = false; // begin outer try catch try { ttsBegin; // begin inner try catch try { // cast exception exception = se.current(); // trhow exception throw exception; } catch { // set flag to indicate the exception was caught inside the transaction caughtInside = true; warning(strFmt("%1 can be caught inside transaction", exception)); // throw exception again to catch it outside of transaction throw exception; } ttsCommit; } catch { // for once, it's ok to catch everyting :) if(caughtInside) { warning(strFmt("%1 can alse be caught outside of the transaction", exception)); } else { info(strFmt("%1 can only be caught outside of the transaction", exception)); } } } Output: Info Info can only be caught outside of the transactionIt is also noteworthy that, when you enter a catch block, there has been a implicit ttsabort, so the transaction has been rolled back. However this is not true for UpdateConflict and DuplicateKeyException when they were caught inside a transaction. Источник: http://microsoft-dynamics-ax-erp.blo...nsactions.html
