axaptacorner: How to create Query in AX 2012 through X ++ code
Источник: http://axaptacorner.blogspot.com/201...2-through.html
============== With the following job we can create and execute the query : Static void Querytest(Args _Args) { Query query; QueryBuildDataSource queryBuildDataSource; QueryBuildDataSource queryBuildDataSource1; QueryBuildRange queryBuildRange; QueryRun queryRun; CustTable custTable; DirPartyTable DirPartyTable; ; query=new query(); //Initialize Query queryBuildDataSource=query.addDataSource(tableNum(CustTable)); //Add Query queryBuildDataSource.addSortField(fieldNum(custTable,AccountNum),SortOrder::Descending); //Add sorting queryBuildRange=queryBuildDataSource.addRange(fieldNum(CustTable,AccountNum)); // Add Range queryBuildRange.value(queryValue('11')+('*')); // Add Query Value queryBuildRange=queryBuildDataSource.addRange(FieldNum(CustTable,AccountNum)); queryBuildRange.value(queryValue('22')+('*')); //queryBuildDataSource1=queryBuildDataSource.addDataSource(tableNum(CustTrans)); //Add other Data Source for Joining //queryBuildDataSource1.relations(true);// Enable Relation // queryBuildDataSource1.joinMode(JoinMode::InnerJoin);//Define Join Mode queryRun= new QueryRun(query); //Pass query to run it while(queryRun.next()) { custTable=queryRun.get(tableNum(CustTable)); print(strFmt("Customer Name, Account num and Currency are %1 , %2 and %3",DirPartyTable::findRec(CustTable.Party).Name,CustTable.AccountNum,CustTable.Currency)); pause; } } Happy AX coding!!!!! Источник: http://axaptacorner.blogspot.com/201...2-through.html
