Старый 18.08.2011, 18:11   #1
emeadaxsupport: Store connect - IDispatch error #3119: Violation of PRIMARY KEY
Источник: http://blogs.msdn.com/b/emeadaxsuppo...imary-key.aspx
Title: Store connect
PRIMARY KEY
Affected products:
Dynamics AX 2009 SP1 RU6 R2
Dynamics AX 2009 SP1 RU7 R2 Refresh
Description:
When running the N-jobs to move over data to the POS, the
following information occurs in the store connect
Violation of PRIMARY KEY constraint 'I_20137STAFFIDX'. Cannot insert duplicate
key in object 'dbo.RBOSTAFFTABLE'. 2011-08-16
07:34:53.000
N-1060
Cause:
In the Transfer field list
(Retail Scheduler/Subjobs/Setup/Transfer Field List) the field type on all to fields
are set to None
Picture illustrates how it
should look like:
Solution:
If you read the fields with store connect from the menu
(Retail Scheduler/Distribution location/Functions) Then all field types are
restored to the correct values
Author: Kim
Editor: Kim
Date: 18. August 2011
kamalblogs: Using GUID as primary key in Dynamics Ax Blog bot DAX Blogs 6 05.01.2011 12:19
DynamicsAxSCM: Personalization of Role Centers in Dynamics AX 2009 Blog bot DAX Blogs 0 21.06.2010 16:05
kamalblogs: Renaming a Primary key like ItemId in Dynamics Ax Blog bot DAX Blogs 0 15.06.2010 20:05
DAX 2009 & UtcDateTime & Primary Key SRF DAX: Программирование 8 05.06.2009 07:05
Часовой пояс GMT +3, время: 08:25.
