Старый 13.07.2011, 16:11   #1
daxdilip: Troubleshooting Dyamics AX Error No Devices found
Источник: http://daxdilip.blogspot.com/2011/07...-error-no.html
Issue:
Recently on one of the client machine, this error message "No Devices found" started popping up while the AX Client is loaded.
Solution:
This is caused by an unregistered ocx file on the client.
To fix this you will need to register the smmPhone.ocx located in C:\Program Files\Microsoft Dynamics AX\40\Client\Bin folder using regsvr32
Command line is:
regsvr32 C:\Program Files\Microsoft Dynamics AX\40\Client\Bin\smmPhone.ocx
but had to go to a cmd window, cd to the C:\Program Files\Microsoft Dynamics AX\40\Client\Bin folder and then run
regsvr32 .\smmPhone.ocx
Restart the box.
daxdilip: Troubleshooting Dynamics AX 2009 EP Thread abort Exception Error Blog bot DAX Blogs 0 05.02.2011 07:13
daxdilip: Troubleshooting Dynamics AX 2009 SSRS Report Data methods displaying #Error Blog bot DAX Blogs 0 26.01.2011 18:11
daxdilip: Dynamics AX Troubleshooting AOS Error Internal Error occured executing stored procedure when creating session for the AOS Blog bot DAX Blogs 0 23.12.2010 07:11
Часовой пояс GMT +3, время: 18:38.
