Старый 23.04.2011, 07:11   #1
kranthiax: Updating The vendTrans Table
Источник: http://kranthiax.blogspot.com/2011/0...ans-table.html
Hi the below code help you to insert custom created field values from a journal(LedgerJournalTrans) to the vendTrans table.
The insertion and updation of the vendTrans fields is done with the help of CustVendTrans Map
Follow the below setups when you add a new field to the ledgerJournalTrans and update it to vendTrans table...
1. Add the field to the custVendTrans Map - before that add field to ledgerJournalTrans and vendTrans.
2. Create a new mapping in the VendTrans of custVendTrans Map
CustVendTrans.ProjId == VendTrans.ProjId
3. Class - CustVendVoucher
In the Class declaration add a variable
ProjId updateProjId;///Kranthi
4. Add a new method to CustVendVoucher class
ProjId parmUpdateProjId(ProjId _projId = updateProjId)
updateProjId = _projId;
return updateProjId;
5. In the initCustVendTrans methid of CustVendVoucher class add this line
custVendTrans.ProjId = updateProjId;
6. Class - VendVoucher -> in the newVendVoucherJournal method of vendVoucher class place the below line of code
vendVoucher.parmUpdateProjId(_ledgerJournalTrans.ProjId);
7. Compile the two classes
Hope this code will help you...
Халтура в AX2009: идентификаторы из USR в GLS, GLP и даже SYS-слоях EVGL DAX: Программирование 2 21.02.2011 19:44
emeadaxsupport: Identifying damaged Table objects in the AOT MetaData Blog bot DAX Blogs 0 16.03.2010 21:05
PatrickChua: Temporary table Blog bot DAX Blogs 0 04.05.2009 14:05
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 20:36.
