MCT
TFS 2010 и Dynamics Ax 2009
Кто нить пытался дружить TFS 2010 и Dynamics Ax 2009?
Я застрял на сообщении об ошибке X++: Team Foundation services are not available from the server. Technical information (for administrator): TF253022: , Team Foundation Server. - : [url]http://go.microsoft.com/fwlink/?LinkId=166481[/url] 1. Visual Studio Team System 2008 Team Explorer 2. Microsoft Visual Studio 2008 Service Pack 1 3. Visual Studio Team System 2008 Service Pack 1 Forward Compatibility Update for Team Foundation Server 2010
Axapta book for developer |
You will need to re-install Visual Studio 20087 SP1 *after* installing Team Explorer 2008; you can then apply the TFS2010 Forward Compatibility Hotfix (KB974558) - I've had exactly the same problem on Windows Server 2003 and this fixed the issue
http://blogs.msdn.com/b/granth/archi...o-connect.aspx |
MCT
My problem is VS 2010.
I know that if I have vs 2008, only I need to install KB974558. And more TFS 2010 does not support oficially. That means I may do not have any error at first, but lately some futures may not work.
Модератор
Перенести ветку в DAX in English ?
-ТСЯ или -ТЬСЯ ? |
Модератор
Сообщение от MikeR
Код: Team Foundation services are not available from the server. Technical information (for administrator): TF253022: необходимо заранее применить к клиенту обновление, чтобы подключиться к выбранному Team Foundation Server. Для получения этого обновления перейдите на веб-сайт корпорации Майкрософт: http://go.microsoft.com/fwlink/?LinkId=166481 2) Цитата:
TF253022: You must update your client with the Forward Compatibility Update in order to connect to the Team Foundation Server that you selected. To obtain this update, go to the Microsoft Web site: http://go.microsoft.com/fwlink/?LinkID=166481”
Here are more explicit details of that update: Visual Studio Team System 2008 Service Pack 1 Forward Compatibility Update for Team Foundation Server 2010 (Installer) http://www.microsoft.com/downloads/e...c-6c5b208ec54d After downloading and installing the update then forcing yet another build all is now working
This posting is provided "AS IS" with no warranties, and confers no rights. |
Модератор
MikeR Вы пробывали устанавливать рекомендации ?
MCT
Сообщение от Vadik
![]() Так, так .. 3. Visual Studio Team System 2008 Service Pack 1 Forward Compatibility Update for Team Foundation Server 2010 != Visual Studio Team System 2008 Service Pack 1 Forward Compatibility Update for Team Foundation Server 2010 (Installer) ? Или я уже ничего не понимаю...
Axapta book for developer Последний раз редактировалось MikeR; 27.12.2010 в 12:54. |
| За это сообщение автора поблагодарили: MikeR (1). | |
#9 |
MikeR, проблему вирішили?
#10 |
MCT
Проблема remained.
Axapta book for developer Последний раз редактировалось MikeR; 29.12.2010 в 17:59. |
| Теги |
| ax2009, team foundation server, tfs |
