Rahul Sharma: Dynamics AX Build Numbers
Источник: http://feedproxy.google.com/~r/Rahul...d-numbers.html
============== List of Dynamics Ax version and kernel/application builds. These numbers are changed when you install new service pack / hotfix / roll-up. So, check above link to know which version of Ax SP / hotfix /roll-up you are on. Other than checking your Ax kernel / application version from the Ax > Help > About Microsoft Dynamics Ax, you can try following as well. Ax Client Kernel Version: Ax help form shows this number as a kernel version that is your current client. To know which version of client you are running, check your Ax client executable from the Ax client installation location. ![]() Ax client executable Ax Server Kernel Version:To know which version of AOS you are running, check your Ax server executable from the Ax AOS installation location. ![]() Ax server executable Ax Application Version: This is a static text in the Ax class. This is updated when you upgrade / install SP / hotfix etc. ApplicationVersion::applBuildNo(). Join this blog if you liked this post and feel free to post your comment / feedback / queries. www.RahulSharma.in Источник: http://feedproxy.google.com/~r/Rahul...d-numbers.html |
