Старый 30.08.2010, 03:28   #1
sumitax: Customize Document handling
Источник: http://sumitax.wordpress.com/2010/08...ment-handling/
While working on document handling I found out if user want to make mandatory for user to add documents for specific Ax record,then you have to make changes to Standard Application Class “Info” in method docu() . For example for  you can make it mandatory  for user to add a PDF document (Internal PO confirmation ) for all  Purchase order records with Status=Received.
Shekhar: Dynamics AX : Document handling Blog bot DAX Blogs 0 30.03.2010 15:05
paruvella: Dynamics Ax Document Handling For The Mails Using Drag n Drop Blog bot DAX Blogs 0 20.11.2009 20:05
paruvella: Dynamics Ax Document Handling using File Drag n Drop Blog bot DAX Blogs 0 12.11.2009 21:05
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 20:12.
