Старый 01.07.2010, 22:07   #1
axaptapedia: Sysmailerattachments
Источник: http://www.axaptapedia.com/Sysmailerattachments
Summary: New page: If you use SMTP to send attachments, you cannot rename the attachment without saving it to disk and renaming it there. This new method on the SysMailerAttachments class applies a techniqu...
If you use SMTP to send attachments, you cannot rename the attachment without saving it to disk and renaming it there. This new method on the SysMailerAttachments class applies a technique described on the web. The method should be called just after the attachment is added to the end of the email's attachment collection.
void renameAttachment(str _newName)
    InteropPermission permission = new InteropPermission(InteropKind::ComInterop);
    SysMailerFields fields;
    int             item;
    COM             _BodyPart;
    permission.assert();
    item = _COM.count();  // last attachment in collection
    _BodyPart = _COM.item(item);
    fields = SysMailerFields::create(_BodyPart.fields());
    fields.add("urn:schemas:mailheader:content-disposition", "attachment; filename="+_newName);
The method was developed for AX2009 SP1 but likely can be backported to earlier versions.
axaptapedia: Tutorial Password Blog bot DAX Blogs 1 22.05.2009 21:23
axaptapedia: Startup Tool Blog bot DAX Blogs 0 13.02.2009 02:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 21:05.
