Старый 05.05.2010, 12:05   #1
Kashperuk Ivan: Tool: DEV_SysTableBrowser and DEV_CreateNewProject tools now on AX 2009
Источник: http://kashperuk.blogspot.com/2010/0...owser-and.html
3 or so years ago I created a couple of tools that provide extra capabilities for AX developers, specifically, ease up the creation of a new project with a predefined structure and name pattern, and add functionality to the way we browse tables with the standard SysTableBrowser, allowing to specify the exact fields you want to see, browsing temporary tables. Both tools were also available as Tabax plugins
You can read more about the tools, as well as Tabax, on the following pages on Axaptapedia:
DEV_SysTableBrowser home page on Axaptapedia
DEV_CreateNewProject home page on Axaptapedia
You can download the new versions of these tools through the pages on Axaptapedia, or directly from my SkyDrive: DEV_SysTableBrowser, DEV_CreateNewProject
If you are unfamiliar with these tools, I suggest you go through Axaptapedia, as it also contains a detailed description of the features provided.
A couple of things I would like to note:
  • There is a kernel bug in AX 2009 that heavily impacts the SysTableBrowser user experience. It takes around 10 seconds each time you want to browse the contents of a specific table. This bug was only fixed in AX6, so AX 2009 users might have problems enjoying the DEV_SysTableBrowser tool.
  • To mitigate this bug (possibly), in AX 2009 the behavior of SysTableBrowser changed a bit. Instead of re-opening the browser window each time the user changes from All fields to AutoGroup only, now 2 grids with these fields are added from the beginning, and hidden/shown based on user selection. DEV_SysTableBrowser provides much more flexibility when selecting the fields to display, so I was not able to follow the same approach. Thus, see bullet 1
  • I have not added any new AOT nodes to the template in DEV_CreateNewProject tool (Data sets, Report Libraries, etc). I don't think AX developers will invest that much time into SSRS reports and EP, and in these cases they will be able to manually create the remaining group nodes in the project.
Let me know if you have comments, suggestions or ideas for these tools.
Thanks
Старый 05.05.2010, 17:35   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Кстати, оказывается, баг с Обозревателем таблиц пофиксили в Hotfix Rollup 3 для АХ 2009.
Я добавил этот код в хро, так что у кого АХ 2009 с хотфиксом, тому повезло.
За это сообщение автора поблагодарили: gl00mie (10).
Часовой пояс GMT +3, время: 02:00.
