Afna CRM: Button that starts a workflow
Источник: http://a-crm.blogspot.com/2008/07/bu...-workflow.html
============== My client wanted to have a button that starts a specific workflow on the form. So after analyzing some javascript I ended with this code: var a = new Array(crmFormSubmit.crmFormSubmitId.value); var sIds = crmFormSubmit.crmFormSubmitId.value+";"; var sEntityTypeCode = "10004"; //Replace this with your entity type code var sWorkflowId = "{BE7E47C0-2452-4F44-8CCA-425B83A7A8FB}"; //Replace this with your actual workflow ID var iWindowPosX = 500; //Modal dialog position X var iWindowPosY = 200; //Modal dialog position Y var oResult = openStdDlg(prependOrgName("/_grid/cmds/dlg_runworkflow.aspx")+"?iObjType=" + CrmEncodeDecode.CrmUrlEncode(sEntityTypeCode) + "&iTotal=" + CrmEncodeDecode.CrmUrlEncode(a.length) + "&wfId=" + CrmEncodeDecode.CrmUrlEncode(sWorkflowId)+ "&sIds=" + CrmEncodeDecode.CrmUrlEncode(sIds) , a, iWindowPosX, iWindowPosY); Of course this is not supported by Microsoft. You use it at your own risk. Источник: http://a-crm.blogspot.com/2008/07/bu...-workflow.html
