Microsoft Dynamics CRM Team Blog: Managing a telemarketing campaign
Источник: http://blogs.msdn.com/crm/archive/20...-campaign.aspx
============== Welcome Guy Riddle, CRM MVP, and today's guest blogger. How do we go about setting up a telemarketing campaign through Microsoft Dynamics CRM? Here is the challenge - we have acquired a list of Companies that we want our telesales team to call, but it is not quite as straightforward as ‘assigning’ a number of the records to each member of the telesales team – as often is the case with telemarketing there are other requirements that come into play:
The key in all of this is that we don’t want our telesales operators spending lots of time closing/creating activities and having to think about what to do after each call. The first we need to do is setup a number of appropriate Queues inside CRM: We have two ‘primary’ queues for East Coast and West Coast – and secondary queues where the ‘call back’ phone calls will reside. We the need to add additional attributes to Account and Phone Call entities:
And finally, we need to build the Workflow rules:
Note, I have added some simple ‘call script’ statements to help the operator. If you are planning multiple campaigns over time you may wish to consider using a campaign code in the subject line rather than a geographic location code.
Note, the ‘Record attributes change’ is based only on the attribute ‘Wrap Up Code’.
Note, I am using a sub process here just to highlight the use of ‘sub processes’ within the workflow context – the same statements could have been directly embedded in the previous workflow rule itself. The telemarketing campaign should now flow like this: 1. New company added to CRM in LA (West Coast) 2. Phone call automatically created for the Company and moved to the appropriate Queue 3. Telemarketing operator takes the first call in the queue and attempts to call prospect. Operator updates call with Wrap up code and saves and closes that record – they are then free to move on to the next call. In this case it was a ‘busy’ signal (so we want a call back call to be created). 4. Workflow automatically closes the originating phone call and updates the Company record. 5. Workflow automatically generates a new call back phone call and moves it to the appropriate Call back queue. 6. Phone call activities can now easily be filtered; exported to Excel or reported on using the Report Wizard. For the purposes of this example I used the CRM object ‘Accounts’ for the telemarketing campaign to be based on – but it could quite easily be Leads or Contacts and the process that I covered in this example can easily be adapted to meet your own specific requirements. Guy Riddle Microsoft CRM MVP Источник: http://blogs.msdn.com/crm/archive/20...-campaign.aspx
