axaptapedia: Progress Bar
Источник: http://www.axaptapedia.com/Progress_Bar
============== Summary: /* Introduction */ <div>== Introduction == A progress bar is a graphical representation of a job's progress and they are used extensively in the application. If a long running process displays a progress bar, the user can monitor the progress and can estimate the approximate time of completion. It is best practice to always display a progress bar during a lengthy process. == Progress Bar within a batchable class == The RunBase framework has methods which will initialize the progress bar so that you can focus on coding the process. // progress bar Runbase demo public void run() { str text; int percent; int counter; int64 progressTotal = 200; // hard coded for demo purpose (this is normally calculated) ; this.progressInit("Processing", progressTotal, #AviFormLetter); progress.setText("Item"); for (counter = 1; counter
| Тема | Ответов | |||
| axaptapedia: RunBaseBatch | 0 | |||
| axaptapedia: Progress Bar | 0 | |||
| axaptapedia: Configuration in title bar | 1 | |||
| Как правильно работать с Progress bar? | 2 | |||
