Старый 30.05.2008, 18:05   #1
axaptapedia: Maps
Источник: http://www.axaptapedia.com/Maps
Summary: Using methods
'''Maps''' is a logical collection of almost identical [[table]]s. A map is a compensation for the fact that tables cannot inherit properties from one another. The critical different is that even though Map resembles a table at first glance, it does not contain data but functions rather as a library of methods intended to be shared by several tables.
Maps is located in the [[AOT]] in tables.
==Using methods==
The syntax for calling a method in Maps is:
Table.Map::Method();
Note that the '::' is actually a a dynamic call when using it with Maps.
[[Category:Table development]]
[[Category: Map development]]
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axaptapedia: Maps Blog bot DAX Blogs 0 04.06.2008 09:05
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 12:02.
