ax-som: BOM explosion
Источник: http://ax-som.blogspot.com/2008/01/bom-explosion.html
============== Do you want to get the BOMExplosion by code? If so, you could use the class BOMSearch. All you need is one method which will be called several times. Example: X++: void browseThroughBOM(BOMSearch _clsBOMSearch) { BOM LtabBOM; InventTable LtabInventTable; ; while (_clsBOMSearch.next()) { LtabBOM = _clsBOMSearch.BOM(); LtabInventTable = LtabBOM.inventTable(); info(LtabInventTable.ItemId); if(LtabInventTable.ItemType == ItemType::BOM) this.browseThroughBOM(BOMSearch::newBOMIdDate(LtabInventTable.BOMId(syst emDateGet()), systemDateGet())); } } BOMSearch::newBOMIdDate(YourBOMId, systemDateGet())) Источник: http://ax-som.blogspot.com/2008/01/bom-explosion.html
