Старый 30.10.2007, 05:03   #1
Issues concerning X++: Difference between " and ' ?
Источник: http://blogs.msdn.com/x/archive/2007...tween-and.aspx
We have been asked whether there is any difference between the two types of quotes that can be used by Ax. The answer is very simple: X++ makes absolutely no distinction between the two. The reason that there are two quote characters is to facilitate constructs themselves containing quote characters, like
str s = ‘’;
Writing this with only one quote character would be difficult to read because escape characters would have to be used to distinguish the quotes defining the extent of the string from those that occur in the string, as
str s = "";
That said, the application community has best practices that mandate that programmers use '(single quotes) for text that cannot appear on UI, like
System.Int32 myVar = CLRInterop::CLRNull('System.Int32');
Whilst text that does should use double quotes for text like myButton.Label = "@SYS12345";
</SPAN>
Issues concerning X++: Getting rid of the "Loss of precision" warning message Blog bot DAX Blogs 2 12.07.2007 18:22
Использование "like" при работе с классом "QueryBuildRange" poul DAX: Программирование 18 11.08.2006 12:20
Превышение кол-ва в "немедленная поставка" кол-ва "к поставке" Pegiy DAX: Функционал 16 23.03.2004 20:03
"LIKE" и "OR" в "qbds" @x DAX: Программирование 14 20.01.2004 13:20
Поля "Автор", "Автор модификации" xconsul DAX: Функционал 1 22.10.2003 09:44
Часовой пояс GMT +3, время: 20:37.
