Старый 23.11.2006, 16:00   #1
Axapta Lessons: Menu Properties.
Источник: http://axapta-lessons-learned.blogsp...roperties.html
Each menu has a number of properties, which we can find in the property sheet. The next table gives an explanation of the available properties. Not all of the properties require a value.
Name:Name of the menu in the AOT.
Label:Enter the name of the menu displayed on the screen.
HelpText:Create a help string for the menu.
The help string is displayed below in the status bar.
ConfigurationKey:
SecurityKey:
NeededAccessLevel:Define the minimum access required. The access rights are: NoAccess, View, Edit, Add and Delete.
SetCompany:Have the system change company when the menu is opened.
When set to Yes: Each time the menu is activated the company changes to what it was when the menu was first activated.
CreatedBy:A read-only property set by the system.
Gives the name of the user who created the object.
CreatedDate:A read-only property set by the system.
Gives the date when the object was created.
ChangedBy:A read-only property set by the system.
Gives the name of the user who last modified the object.
ChangedDate:A read-only property set by the system.
Gives the date when the object was last modified.
ChangedTime:A read-only property set by the system.
Gives the time when the object was last changed.
LockedBy:A read-only property set by the system.
Gives the name of the user who has currently locked the object.
Remarks: Menus and sub-menus are only displayed if they contain at least one menu item.
Axapta Lessons: Menus. Blog bot DAX Blogs 0 23.11.2006 16:00
Axapta Lessons: Menu Item Properties. Blog bot DAX Blogs 0 23.11.2006 16:00
Axapta Lessons: Menu Items Blog bot DAX Blogs 0 23.11.2006 16:00
Axapta Lessons: Extending the Tools menu and submenus Blog bot DAX Blogs 0 28.10.2006 18:22
Axapta Lessons: Add menu options to the Add-Ins submenu Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 16:09.
