Старый 28.10.2006, 16:40   #1
Fred Shen: Limited sessions in Axapta
Источник: http://fredshen.spaces.live.com/Blog...E4E3!173.entry
Some Axapta system administrator may feel it is really annoying that Axapta allows the user to create multiple Axapta sessions and log in as the same user. If you want to give the user notification prior to logging in as the same User ID, here comes the solution.
Under the Info class, modified the startupPost method like the codes below:
void startupPost()
    int         counter;
    int         num = 0;
    int         maxSessions = Info::licensedUsersTotal();
    xSession    session;
    UserInfo    userInfo;
    UserId      currentUserId;
    currentUserId = curuserid();
    for(counter = 1; counter < maxSessions;counter++ )
        session = new xSession(counter, true);
        if(session && session.userId())
            select firstOnly userInfo
                where userInfo.id == session.userId();
            if (userInfo && (currentUserId == session.userId()))
                num++ ;
    if (num > 1)
        if(box::yesno("The same user id can't log in twice. Do you want to log in anyway? ",
                   DialogButton::Yes, "Log in", "Log out") == DialogButton::No)
            infolog.shutDown(true);
Please notice that, if you modify the startupPost method of Application class, that works only in 2-tier environment. For both 2-tier and 3-tier environment, it is recommended to modify the startupPost method of Info class.
Fred Shen: Convert Axapta date type value to datetime type value in SQL Server Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Read and alter registry settings in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Axapta build number Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Tips on optimizing primary index in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Use resource files in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 18:04.
