Старый 27.11.2012, 15:11   #1
ax-erp: Method Overloading
Источник: http://microsoft-dynamics-ax-erp.blo...erloading.html
Sometimes we need to change the standard behaviour of form controls. It is not a big deal when when it concerns overriding form controls' methods in design time in AOT. But when it comes to doing that dynamically it may not be as simple as a piece of cake.
From the beginning the goal was to make sorting functionality on the grid created by SysTableLookup class impossible for the user. It might have been a good solution to change the code like the following
formRun = classfactory.formRunClass(args);
form = formRun.form();
// allow the class to react on the form's events
formRun.controlMethodOverload(true);
formRun.controlMethodOverloadObject(this);
// here override Sorting on all datafields added on the grid
this.overrideSortMethodOnDatafields(form);
<span class="rem">//
ax-erp: Overriding method for a control in dialog (RunBase framework) Blog bot DAX Blogs 0 18.09.2012 18:11
Часовой пояс GMT +3, время: 12:24.
