Старый 07.02.2024, 12:11   #1
d365fokartik: Update NuGet Task version to 2.* D365 Finance and operations
Источник: https://d365fokartik.home.blog/2024/...nd-operations/
If Azure are using task version 0 and pipeline Build ending partially successful. You need to update task version and Command and arguments. Things to update. install -Noninteractive $(NugetConfigsPath)\packages.config -ConfigFile $(NugetConfigsPath)\nuget.config -Verbosity Detailed -ExcludeVersion -OutputDirectory “$(NugetsPath)”
axinthefield: Update to using Application Insights for monitoring D365 Finance and Operations Blog bot DAX Blogs 0 11.11.2022 06:11
stoneridgesoftware: How ‘One Version’ Affects Dynamics 365 Finance and Operations Users Blog bot DAX Blogs 0 10.05.2019 19:16
alirazazaidi: Serialization version mismatch detect, make sure the runtime dlls are in sync with the deployed metadata D365 For finance and operations Blog bot DAX Blogs 0 06.05.2019 13:11
stoneridgesoftware: How to Extend Sales Order Update Functionality to Custom Fields in D365 Finance and Operations Blog bot DAX Blogs 0 08.02.2019 22:11
Часовой пояс GMT +3, время: 09:33.
