Старый 23.01.2021, 00:11   #1
D365FO data entities with financial dimension requires special field names
Источник: http://alexvoy.blogspot.com/2021/01/...financial.html
While creating data entities using financial dimensions, do not forget that those are backed in background by special classes via SysDataEntityPersister class
Those latter help resolving selected values (similar to what we see in segmented entry in forms).
Each class is meant to serve a particular EDT, for example
/// The LedgerAccountDimensionDataEntityResolver class resolves data entity ledger account values.
System.ComponentModel.Composition.ExportMetadataAttribute("DimensionSFKType", identifierstr(LedgerDimensionAccount)),
System.ComponentModel.Composition.ExportAttribute("Microsoft.Dynamics.AX.DimensionDataEntitySFKFieldResolver")
public class LedgerAccountDimensionDataEntityResolver extends DimensionDataEntitySFKFieldResolver
Name accountStructure;
In order to let it work correctly, some fields in your data entity must have particular names.
public class DimensionDataEntityConstants
public static const str HasDimensionDataSourcesCustomPropertyName = '__HasDimensionDataSources__';
public static const str ProviderCacheName = 'DimensionDataEntitySFKProviderCacheName';
public static const str AccountStructureSuffix = 'AccountStructure';
public static const str DisplayValueSuffix = 'DisplayValue';
public static const str DisplayValueTypeName = 'DimensionDisplayValue';
sertandev: How to integrate with Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 21.08.2020 15:12
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 12:13.
