Старый 02.08.2019, 15:11   #1
crmtipoftheday: Tip #1288: SLA’s and solutions
Источник: https://crmtipoftheday.com/1288/slas-and-solutions/
From the short and sweet department: If you have SLA’s in your solution and the SLA’s exist in the target environment to which you are importing your solution, the SLA’s will be deactivated after you import the solution.
If you activate SLA’s via the user interface, your only option is to activate them one at a time.
Lesson learned — avoid reimporting SLA’s unless they have changed. Consider putting SLA’s in their own solution.
Часовой пояс GMT +3, время: 19:25.
