Старый 05.03.2019, 14:11   #1
crmtipoftheday: Tip #1226: Avoid Model-Driven Failure
Источник: https://crmtipoftheday.com/1226/avoi...riven-failure/
When deploying model-driven apps, there are multiple potential points of failure that can affect users’ ability to access part or all of the app. The following is a non-exhaustive list of some of the more common areas to check if the user can’t see the app or access certain parts of it:
  • User is missing model-driven app privilege in security role
  • User’s security role is not granted access to the app
  • User’s security role or licence doesn’t give them access to some entities or records in the app.
  • User’s role doesn’t have access to forms in the app
  • User’s role doesn’t have access to dashboards in the app
  • User’s role doesn’t have access to business process flows in the app
Lesson learned: building an app is (fairly) easy but due diligence must be taken to ensure that the user’s of the app have appropriate privileges at multiple levels of components.
(Cover photo by Firdaus Roslan on Unsplash)
crmtipoftheday: Tip #1209: Embedding canvas apps in model-driven forms Blog bot Dynamics CRM: Blogs 0 12.12.2018 14:11
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
daxmusings: PSA: AX7 Build Failure on Generate Packages / Model Export Blog bot DAX Blogs 0 01.11.2017 09:11
stoneridgesoftware: Dynamics 365 for Operations: How to Create a New Model Blog bot DAX Blogs 0 11.02.2017 01:11
Часовой пояс GMT +3, время: 06:43.
