Старый 21.02.2019, 01:14   #1
d365technext: SQL In Operator in D365FO
Источник: http://d365technext.blogspot.com/201...in-d365fo.html
Microsoft Introduce In Operator in X++ Syntax, but it will work with Enums only.
Following are the example how you can use this
SalesTable salesTable;
container con = [SalesType::Sales, SalesType::ReturnItem, SalesType::Subscription];
while select SalesId from salesTable
where salesTable.SalesType in con
Info(salesTable.SalesId);
d365technext: Environment hot fixes D365FO Blog bot DAX Blogs 0 16.08.2018 14:11
d365technext: D365FO One Box VM SQL Password Blog bot DAX Blogs 0 10.08.2018 13:11
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1A [Introduction and SQL Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
Nav developer: Basic SQL - Overview of NAV specific SQL features for application consultants Blog bot Dynamics CRM: Blogs 0 05.11.2008 11:52
Часовой пояс GMT +3, время: 11:40.
