sinedax: How to avoid Retail Module configuration reset - Dynamics 365 for Finance & Operations LBD
Источник: http://sinedax.blogspot.com/2018/09/...il-module.html
============== Hi mates, if in your LBD implementation the Retail Module disappear after a Deployment, here how to avoid it. After a chat with Microsoft, to prevent DB sync from resetting the config keys (Retail in my case), issue the following command against the AxDB Database from sql server management studio: INSERT INTO SQLSYSTEMVARIABLES (PARM, VALUE, IPARM, IVALUE) VALUES ('FirstSyncSuccess', 1, 20, NULL) It seems that in the next months a new KB will be release in order to fix that. In the next Deployments you can sleep peacefully that the Retail Module will be there again! Till soon! Источник: http://sinedax.blogspot.com/2018/09/...il-module.html
