d365technext: Performance Tool in D365FO
Источник: http://d365technext.blogspot.com/201...in-d365fo.html
============== Performance Tool in D365FO Today, I found standard feature of performance optimization in Dynamics 365 For Finance and Operations ....Microsoft called this feature as Performance tool You can find the navigation of this tool as below... You will find lots of option here to optimization, Over internet I didn't find any documentation of this feature. So I am sharing some items i have explored. There is Text box where we can Enter of the number of records on which we want to check performance using this tool. Microsoft Divide this Feature in 4 Category
Data Manipulation In this MS Checking the performance of Insert Update Record Insert List Insert Record set update record set delete from Query In this section testing will perform on the below points
In this section we can check the performance on Temp DB and In Memory.... Cache The same number of records will store in cache ... Important Note that running for 1,000 records will take approximately 1 minute, so be careful using larger numbers not to run into form timeouts. The max record count is 100,000. Источник: http://d365technext.blogspot.com/201...in-d365fo.html
| За это сообщение автора поблагодарили: Logger (1). | |
