Старый 16.04.2017, 02:31   #1
organicax: Starting and Ending part quantities on a production order
Источник: https://organicax.com/2017/04/15/sta...duction-order/
Usually a production order is created for a quantity that came from a demand signal, but sometimes you might not be able to start the full quantities. Maybe that’s because you are trying to balance with other orders or you don’t have enough raw materials. No matter the reason you can start and report quantities in parts as you might need.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
dynamicsaxse: February release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 02.03.2017 01:11
atinkerersnotebook: Configuring Production Control Within Dynamics AX 2012 Downloadable As PDF Blog bot DAX Blogs 0 01.07.2014 22:11
atinkerersnotebook: Dynamics AX 2012 Barebones Configuration Guide #13 – Configuring Production Control Is Available Blog bot DAX Blogs 0 23.04.2014 22:11
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
Часовой пояс GMT +3, время: 23:22.
