Старый 10.04.2017, 13:11   #1
dynamicsaxhints: Specifics of update_recordset crossCompany in AX 2012
Источник: http://dynamicsaxhints.blogspot.com/...recordset.html
Have you ever tried to run update_recordset crossCompany statement?
Yes, it is possible. There are only 5 methods in standard AX code with such statement, but it can be very useful for data update jobs in multi company environment.
Tables:
TaxTransGeneralJournalAccountEntry.moveTaxForeignKeyToTaxTrans()
RetailLoyaltyConflictCard.migrateConflictCards()
Classes:
ReqDemPlanForecastChangeTracker.applyAllChanges()
ReleaseUpdateDB63_HRMMinor.updatePositionForecastBudgetAcctLine()
ReleaseUpdateDB63_HRMMinor.updatePositionForecastCompGroupRefPoint()
You must disable update method, database log and alerts, otherwise compiler will throw an error, for example:
transTable.skipDataMethods(true);
transTable.skipDatabaseLog(true);
transTable.skipEvents(true);
update_recordSet crossCompany transTable
setting loyaltyCardId = conflictCard.NewCardNumber
where transTable.loyaltyCardId == conflictCard.CardNumber
&& transTable.dataAreaId == conflictCard.Company;
If you are still not convinced, then there is another example below.
static void updateRecordSetCrossCompany(Args _args)
CustTable custTable;
PaymTermId oldPaymTermId = 'Net10', newPaymTermId = 'Net11';
// original state
while select crossCompany dataAreaId, count(RecId) from custTable
group by custTable.dataAreaId
where custTable.PaymTermId == oldPaymTermId
info(strFmt('Original: company %1 has %2
customers with PaymTermId %3.'
custTable.dataAreaId, custTable.recId, oldPaymTermId));
// update
custTable.skipDatabaseLog(true);
custTable.skipDataMethods(true);
custTable.skipEvents(true);
update_recordSet crossCompany custTable
setting PaymTermId = newPaymTermId
where custTable.PaymTermId == oldPaymTermId;
// new state
where custTable.PaymTermId == newPaymTermId
info(strFmt('New: company %1 has %2 customers with PaymTermId %3.',
custTable.dataAreaId, custTable.recId, newPaymTermId));
The job results are:
dynamicsaxhints: What is wrong: crossCompany update job in AX 2012 Blog bot DAX Blogs 0 27.03.2017 11:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Часовой пояс GMT +3, время: 08:44.
