Старый 26.01.2017, 23:12   #1
stoneridgesoftware: Dynamics AX Tab Missing from Excel Menu,Though Dynamics AX Office Add-ins Has Been Installed
Источник: https://stoneridgesoftware.com/dynam...een-installed/
Is your Dynamics AX tab missing from the Excel menu, even though the Dynamics AX Office add-ins has been installed? If your Microsoft Dynamics AX 2012 Client and Microsoft Office Add-ins is installed on the machine (you can see this in Programs and Features> Installed Updates), you’ll find the solution below.
Solution for missing Excel tab missing in Dynamics AX:
Make sure the COM Add-in is active in Excel. Do this by opening Excel, then go to File> Options> Add-Ins. In this window, under Active Application Add-ins, you should see Microsoft Dynamics AX-Add-in for Microsoft Excel listed like below.
If it is not, then click on the drop down by Manage: and select COM-Add-in and click on Go.
Check the box by Microsoft Dynamics AX Add-in for Microsoft Excel and click Ok.
Now you should see Dynamics AX in your Excel menu.
Close out of Excel, and re-open it. If Dynamics AX is missing again, then change the LoadBehaviour to a 3 in the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\Excel\Addins\Microsoft.Dynamics.AX.Framework.OfficeAddin.Excel
stoneridgesoftware: TFS Code Repository and Dynamics AX Blog bot DAX Blogs 0 16.06.2016 16:11
NAV Team: Upgrading from Microsoft Dynamics NAV 2009 R2 or Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2015 Blog bot Dynamics CRM: Blogs 0 23.02.2015 13:00
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 14 Blog bot Dynamics CRM: Blogs 0 12.07.2013 07:13
Karl Tolgu: The Atlas XL Microsoft Office Excel add-in by Globe Software uses the Dynamics AX Business Connector... Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 13:56.
