Старый 01.09.2016, 01:18   #1
organicax: WMS Mobile device menu – License plate build
Источник: https://organicax.com/2016/08/31/wms...e-plate-build/
If you need to move multiple license plates around the warehouse you can have a look at using the parent license plate functionality. You can work with this by building a parent license plate and adding other license plates under the parent through the license plate build menu item.
Here is a quick overview.
AX2012 R3 CU10.
Cheers
Lachlan
Filed under: Warehouse management
organicax: WMS Mobile device menu – Start production order Blog bot DAX Blogs 0 01.09.2016 01:18
organicax: WMS Mobile device menu – License plate break Blog bot DAX Blogs 0 01.09.2016 01:18
organicax: WMS Mobile device menu – Override target license plate Blog bot DAX Blogs 0 06.08.2016 03:27
organicax: WMS Mobile device menu – Display batch disposition codes Blog bot DAX Blogs 0 10.05.2016 17:11
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
Часовой пояс GMT +3, время: 01:49.
