organicax: Setting up a new target market in call center
Источник: https://organicax.com/2016/07/22/set...n-call-center/
============== If you are setting up a call center then you can optionally setup a target market that you can use in your processes like assigning targets to a campaign. When you setup a catalog for a call center and you associate a source code with the catalog then you can also associate the target market for the source code. Here is a quick overview. AX2012 R3 CU10 Cheers Lachlan Filed under: Retail Источник: https://organicax.com/2016/07/22/set...n-call-center/
