Старый 03.06.2016, 17:11   #1
emeadaxsupport: AX 2012 AxUpdatePortal fails with error after about 6 minutes
Источник: https://blogs.msdn.microsoft.com/axs...out-6-minutes/
When running the command [AxUpdatePortal -updateall -websiteurl “…” -verbose] on the EP server it sometimes happens that the execution fails with error:The operation failed to execute. Error: Microsoft Dynamics AX could not locate the Web server… In the Application event log you find a Warning with Event ID 1309 from source ASP.NET 4.0.30319.0: 3001The request... Read more
emeadaxsupport: AX Performance - What information and data to collect when you want to open a support case Blog bot DAX Blogs 0 29.09.2015 15:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
emeadaxsupport: AX 2012 Retail: Creating Offline Database fails Blog bot DAX Blogs 0 14.05.2012 17:11
Часовой пояс GMT +3, время: 23:44.
