It has been a while since I last wrote a posting about the SMTP Server component that we first shipped with Dynamics NAV 5.0. Let’s recap the older posting first as it does list a complete list of patches that one should have applied already and let me take the opportunity to also discuss some previous support cases that were filed at our support service regarding specific Italian localization that only applies to Italian partners / customers. Last but not least some support cases were filed at our support service in regards to Office 365. Let’s also discuss these.
The previous posting can be found here: Double impersonation within a three tier environment and the SMTP Server setup in Microsoft Dynamics NAV. A later patch did came out as well: 2811780 where we added some code to code unit 400 to allow a timer to be configured via C/AL. Previous support cases were filed by Italian partners requesting if they could use our SMTP Server component with Posta Elettronica Certificata which is an alternate connection configuration via SMTP/SSL over port 465. More information about PEC can be found here: IETF and Wikipedia The SmtpClient.EnableSsl property is responsible for this and is discussed on MSDN. Here you can read the following: An alternate connection method is where an SSL session is established up front before any protocol commands are sent. This connection method is sometimes called SMTP/SSL, SMTP over SSL, or SMTPS and by default uses port 465. This alternate connection method using SSL is not currently supported.Last but not least Microsoft Support received several requests from partners how they should configure Dynamics NAV SMTP Server component in combination with Office 365. The good news is that this is possible, but there are some challenges, especially when you use the SMTP Server component in combination with Document Approval system that we shipped with Dynamics NAV. Let’s assume the latter. The prerequisites are:
First command: PS C:Windowssystem32> Set-Executionpolicy -ExecutionPolicy Unrestricted Execution Policy Change The execution policy helps protect you from scripts that you do not trust. Changing the execution policy might expose you to the security risks described in the about_Execution_Policies help topic at http://go.microsoft.com/fwlink/?LinkID=135170. Do you want to change the execution policy? [Y] Yes [N] No [S] Suspend [?] Help (default is "Y"): y Second command: PS C:Windowssystem32> $LiveCred = Get-Credential cmdlet Get-Credential at command pipeline position 1 Supply values for the following parameters: Credential Third command: PS C:Windowssystem32> $Session = New-PSSession -ConfigurationName Microsoft.Exchange -ConnectionUri https://ps.outlook.com/powershell/ -Credential $LiveCred -Authentication Basic -AllowRedirection WARNING: Your connection has been redirected to the following URI: "https://pod51014psh.outlook.com/powershell-liveid?PSVersion=3.0 " WARNING: Your connection has been redirected to the following URI: "https://db3prd0411psh.outlook.com/powershell-liveid?PSVersion=3.0 " Fourth command: PS C:Windowssystem32> Import-PSSession $Session ModuleType Name ExportedCommands ---------- ---- ---------------- Script tmp_2b2tb1qp.44s {Add-AvailabilityAddressSpace, Add-DistributionGroupMember, Add-Mailb... Fifth command: PS C:Windowssystem32> Add-RecipientPermission "Kevin Mels" -AccessRights SendAs -Trustee "Marco Mels" Confirm Are you sure you want to perform this action? Adding recipient permission 'SendAs' for user or group 'Marco Mels' on recipient 'Kevin Mels'. [Y] Yes [A] Yes to All [N] No [L] No to All [?] Help (default is "Y"): Y Identity Trustee AccessControlType AccessRights Inherited -------- ------- ----------------- ------------ --------- kevinmels marcomels Allow {SendAs} False Sixth command: PS C:Windowssystem32> Add-RecipientPermission "Sean Bentley" -AccessRights SendAs -Trustee "Marco Mels" Confirm Are you sure you want to perform this action? Adding recipient permission 'SendAs' for user or group 'Marco Mels' on recipient 'Sean Bentley'. [Y] Yes [A] Yes to All [N] No [L] No to All [?] Help (default is "Y"): Y Identity Trustee AccessControlType AccessRights Inherited -------- ------- ----------------- ------------ --------- seanbentley marcomels Allow {SendAs} False PS C:Windowssystem32> Document Approval setup looks like this: PS C:Windowssystem32> Remove-PSSession $Session To summarize, Marco Mels (marcomels@bergmanz.onmicrosoft.com) configured in the SMTP settings is the trustee and you need to add SendAs recipient for all users that are in the Approval User Setup form. Some other commands to verify the setup if needed: PS C:Windowssystem32> Get-RecipientPermission "Sean Bentley" -AccessRights SendAs Identity Trustee AccessControlType AccessRights Inherited -------- ------- ----------------- ------------ --------- seanbentley NT AUTHORITYSELF Allow {SendAs} False seanbentley marcomels Allow {SendAs} False The Windows Powershell must be started via “Run as Administrator”and you need to specify user credentials within Office365 that does have Administrator permissions. Truly hope this does help you to configure SMTP Server component in Dynamics NAV in combination with Office 365. Regards, Marco Mels CSS EMEA This posting is provided "AS IS" with no warranties, and confers no rights Источник: http://feedproxy.google.com/~r/Micro...ffice-365.aspx
