Старый 14.12.2011, 11:11   #1
Gareth Tucker: How to view Ribbon Definitions in CRM 2011
Источник: http://gtcrm.wordpress.com/2011/12/1...s-in-crm-2011/
Previously the SDK contained ribbon definition XML files in a folder at the following location:
\\sdk\samplecode\cs\client\ribbon\exportribbonxml\exportedribbonxml\
The latest SDK seems to no longer include these files.  So, now you need to generate these yourself using the utility provided.  It’s not hard to do, here’s the steps:
Go to this location:
Double-click the solution file (exportribbonxml.sln) to open this solution in Visual Studio.
Right-click on the Solution in Visual Studio and select Build:
Wait for that process to complete and make sure Visual Studio doesn’t report any errors.  If that all went ok you will now have an exe you can run, at the following location:
\\sdk\samplecode\cs\client\ribbon\exportribbonxml\bin\Debug\
Double click on the exe (ExportRibbonXml.exe) and then provide the details asked of you:
And that should generate the ribbon definition files that you need:
Gareth Tucker: Installing the Customer Care Accelerator (CCA) for CRM 2011 Blog bot Dynamics CRM: Blogs 3 23.12.2011 09:16
Gareth Tucker: Editing Ribbon Buttons in CRM 2011 Blog bot Dynamics CRM: Blogs 0 24.08.2011 09:11
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Online Test Drive Guide Blog bot Dynamics CRM: Blogs 0 05.08.2011 20:13
Gareth Tucker: Getting Started with CRM 2011 Online Fetch XML Reporting Blog bot Dynamics CRM: Blogs 0 19.05.2011 23:13
Часовой пояс GMT +3, время: 08:00.
