Старый 30.09.2015, 11:11   #1
axmfg: New support for serial number registration in production
Источник: http://blogs.msdn.com/b/axmfg/archiv...nsumption.aspx
The hotfix in Microsoft Knowledge Base (KB) article 3093049, which is planned for release in mid-October, enables scenarios where registration of a component’s serial number can be postponed until the time of consumption in production. Here is one of the customer scenarios we have been looking at:
Most of the components we use for our machine assemblies are delivered from vendors. These components are typically received on pallets packed in a quantity of for example 200 pieces. Each component has a unique engraved serial number, but we don’t need to register the serial numbers at product receipt. We just register the receipt of the pallet, so that we don’t have to spend time breaking up the pallet and registering each serial number individually. The serial number also isn’t registered when the warehouse worker picks the component for the production order. However, when the assembly worker mounts the component in the assembly, she reads the engraved serial number on the component and updates it in the system. By registering the serial number at the time of consumption, we can print a list that shows exactly which component serial numbers were used in a given assembly. Then, if we receive a complaint, and the issue that is reported can be tracked to a specific component, we can communicate the serial number back to the vendor. In a worst-case scenario, if the issue is systematic (for example, a batch of bad-quality rubber sealing has been used in the component), the vendor will track all the components that are affected and communicate the serial numbers affected back to us. Because we can track the serial number that is used in a given assembly, we can now identify all the assemblies that are affected and take the necessary measures.
This scenario is now supported in Dynamics AX and can be demonstrated by using a simple bill of materials (BOM) that is named Assembly and a serial-controlled item that is named Component.
In the warehouse, the component is tracked only by location and license plate. The serial number of the individual components on the license plate aren’t known at this point.
A production order is released for the assembly, and warehouse work is created to pick up the component.
The warehouse work is processed without specifying the serial number of the picked component.
The production order is started, and the production picking list journal is created.
The picking list journal can’t be posted unless a serial number is specified. Any attempt to do so will cause the following error message:
This message indicates that a serial number must be registered before the picking list journal can be posted. The new Register serial numbers menu item that has been added to the Inventory Action Pane button can be used to resolve this error.
The journal can now be posted, and the serial number is updated on the issue transaction for the production material line.
The bill of serial for the assembly can now be printed from the tracing tool.
A new field Register serials before consumption has been added to the Tracking dimension groups form to enable this scenario. This field works together with the Capture serial field for the values Picking and Packing. For example, when Picking is selected in the Capture serial field, the serial number also needs to be provided at the time of picking.
axmfg: Output location for the last operation in the production route Blog bot DAX Blogs 0 22.09.2014 18:11
axmfg: Support for Recycled By-products in AX 2012 R3 CU8 Blog bot DAX Blogs 2 09.09.2014 16:01
atinkerersnotebook: Configuring Production Control Within Dynamics AX 2012 Downloadable As PDF Blog bot DAX Blogs 0 01.07.2014 22:11
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
dynamicsaxtraining: Production life cycle Blog bot DAX Blogs 0 16.07.2011 01:23
Часовой пояс GMT +3, время: 15:51.
