Старый 30.04.2015, 18:12   #1
emeadaxsupport: AX 2012 R3 - A user cannot synchronize to a Document Template Library with federated authentication and no error message displays.
Источник: http://blogs.msdn.com/b/axsupport/ar...-displays.aspx
Issue description:
AX 2012 R3 - A user cannot sync to a Document Template Library with federated authentication
and no error message displays,but If you are logged into SharePoint site and try attaching the file then,
it works fine.
Workaround suggestion:
Setup is completed following the article below:
Configure and use Microsoft Dynamics AX document management with Microsoft SharePoint document libraries [AX 2012]
This a known issue and the logon prompt was remove when you are accessing the SharePoint Online
through federated access.
You need to logon to SharePoint online in a browser in order to generate the cookie cache
and fix the synchronization issue.
If you are not using federated authentication, where users have a direct connection to SharePoint Online,
then Dynamics AX client will get a normal logon prompt, and complete a basic authentication over SSL.
Writer: Jos&eacute; Luis Alvarez Mesa <a href="mailto:jalvarez@microsoft.com"jalvarez@microsoft.com/a>
Dynamics AX Sustained Engineering: Making automatic user provisioning for forms-based authentication work Blog bot DAX Blogs 0 05.03.2014 17:11
Rahul Sharma: Claims-Based Flexible Authentication in Dynamics AX 2012 Blog bot DAX Blogs 0 02.05.2012 09:11
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 14:24.
