Старый 29.01.2015, 13:11   #1
East Ocean - Technical: Quickly view schema name and guid in crm form
Источник: http://eastoceantechnical.blogspot.c...d-guid-in.html
Most of the time we need to refer to our CRM entity/ form for schema name during development.
Here is some script which can allow developer to identify via the CRM record form.
Create a file with following code, save as Debug.url extension, so you can use this as shortcut in bookmark to trigger the script. Just copy to Favorite folder, it is ready to use.
[DEFAULT]
BASEURL=http://mscrm:5555/DEV/main.aspx
[DOC_contentIFrame]
BASEURL=http://mscrm:5555/DEV/_root/homepage.aspx
ORIGURL=/DEV/_root/homepage.aspx
[{000214A0-0000-0000-C000-000000000046}]
Prop3=19,15
[InternetShortcut]
URL=javascript:(function(){javascript:var x = 0; while (frames[x].Xrm.Page.data == null) {x++;} frames[x].Xrm.Page.ui.tabs.forEach(function(b){b.setVisible(true);b.sections.forEach(function(c){c.setVisible(true);})}); frames[x].Xrm.Page.ui.controls.forEach(function(a){a.setVisible(true); if (a.setDisabled != null) {a.setDisabled(false);} var span = document.createElement('span'); span.innerHTML = ''; if (frames[x].document.getElementById(a.getName() + '_c') != null) {frames[x].document.getElementById(a.getName() + '_c').appendChild(span);}}); var span = document.createElement('span'); span.innerHTML = ''; frames[x].document.getElementById("form_title_div").getElementsByTagName("div")[0].appendChild(span); var span = document.createElement('span'); span.innerHTML = ''; frames[x].document.getElementById("form_title_div").getElementsByTagName("div")[0].appendChild(span);})();
IDList=
IconFile=http://mscrm:5555/favicon.ico
IconIndex=1
HotKey=0
[Bookmarklet]
ExtendedURL=javascript:(function(){javascript:var x = 0; while (frames[x].Xrm.Page.data == null) {x++;} frames[x].Xrm.Page.ui.tabs.forEach(function(b){b.setVisible(true);b.sections.forEach(function(c){c.setVisible(true);})}); frames[x].Xrm.Page.ui.controls.forEach(function(a){a.setVisible(true); if (a.setDisabled != null) {a.setDisabled(false);} var span = document.createElement('span'); span.innerHTML = ''; if (frames[x].document.getElementById(a.getName() + '_c') != null) {frames[x].document.getElementById(a.getName() + '_c').appendChild(span);}}); var span = document.createElement('span'); span.innerHTML = ''; frames[x].document.getElementById("form_title_div").getElementsByTagName("div")[0].appendChild(span); var span = document.createElement('span'); span.innerHTML = ''; frames[x].document.getElementById("form_title_div").getElementsByTagName("div")[0].appendChild(span);})();
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 8 Blog bot Dynamics CRM: Blogs 1 30.04.2016 10:26
crminthefield: 6 Steps to Add a Deployment Administrator in Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 1 24.03.2016 09:26
Microsoft Dynamics CRM Team Blog: Creating and Publishing a Web Portal to an Azure Cloud Service Blog bot Dynamics CRM: Blogs 0 17.04.2013 23:11
Часовой пояс GMT +3, время: 02:20.
