Старый 06.03.2014, 18:11   #1
atinkerersnotebook: Archive Reports So That You Can Access Then Later On Without Rerunning It
Источник: http://atinkerersnotebook.com/2014/0...-rerunning-it/
Originally posted on Dynamics AX Tip Of The Day:
When you rerun a report, there is a small chance that you will get slightly different report, because flags have been changed, or the report has been modified. If you want to preserve your report as it was when it was originally ran, then you can easily do that by saving it to the Report Archive. Once the report is archived, you can return to it over and over again without even rerunning it.Now you have your very own microfiche system – minus the clunky reader.
View original
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Часовой пояс GMT +3, время: 18:15.
