The URL builder function, GETURL, is released in Microsoft Dynamics NAV 2013 R2 to reduce coding time for developers who need to create various URL strings to run application objects in either the win client, the web client, or on web services. In addition, the GETURL function makes multitenancy features more transparent to C/AL developers.
Details Ever had to construct win client URLs like the one below? dynamicsnav://myserver:7046/myInstance/myCompany/runpage?page=26 Today, Microsoft Dynamics NAV also provides a web client. This means that you must update your code to construct web client URLs too. What about multitenancy? The URL Builder should know if it is running in a multitenant setup and it should know how to choose the right tenant. What about maintaining this code? The good news is that GETURL has been introduced to handle all URL building for you. GETURL automatically handles:
The format is: [String :=] GETURL(ClientType[, Company][, Object Type][, Object Id][, Record]) Where:
GETURL(CLIENTTYPE:WEB,COMPANYNAME, OBJECTTYPE::Page,27,Vendor) Note: It is currently not possible to set filters on the record that you sent as a last parameter to the GETURL function. However, it is possible to write your own code to compute and append the filter string to the URL that is created by the GETURL function. The server name and instance are extracted automatically by GETURL and do not need to be specified by the C/AL developer. Furthermore, the multitenancy setup is transparent to the C/AL developer. No multitenancy parameters are specified when you call GETURL, because the function knows from the server setup if it is running in a multitenant environment and if so, it will add a string like "&tenant=MyTenant" to the URL. When to Use The GETURL function can generally be used every time a URL must be created. The following are some scenarios where the function is particularly useful.
The following are examples of calls to GETURL and their corresponding return value: Command URL GETURL(CLIENTTYPE::Win) dynamicsnav://MyServer:7046/DynamicsNAV71// GETURL(CLIENTTYPE::Web) https://navwebsrvr:443/DynamicsNAV71...nce1/Webclient GETURL(CLIENTTYPE::OData) http://MyServer:7048/DynamicsNAV71/OData GETURL(CLIENTTYPE::SOAP) http://MyServer:7047/DynamicsNAV71/WS/Services GETURL(CLIENTTYPE::Current) ie. When running this code on a Win client session dynamicsnav://MyServer:7046/DynamicsNAV71// GETURL(CLIENTTYPE: efault) ie. When the Server config key DefaultClient is set to Windowsdynamicsnav://MyServer:7046/DynamicsNAV71// GETURL(CLIENTTYPE::Windows,COMPANYNAME) dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/ GETURL(CLIENTTYPE::Windows,'') dynamicsnav://MyServer:7046/DynamicsNAV71// GETURL(CLIENTTYPE::Windows,'NONEXISTING Corp') dynamicsnav://MyServer:7046/DynamicsNAV71/NONEXISTING Corp/ GETURL(CLIENTTYPE::Web,COMPANYNAME) https://navwebsrvr:443/DynamicsNAV71...company=CRONUS GETURL(CLIENTTYPE::Web,'') https://navwebsrvr:443/DynamicsNAV71...nce1/Webclient GETURL(CLIENTTYPE::Web,'NONEXISTING Corp') https://navwebsrvr:443/DynamicsNAV71...ny=NONEXISTING Corp GETURL(CLIENTTYPE::OData,COMPANYNAME) http://MyServer:7048/DynamicsNAV71/OData/Company('CRONUS') GETURL(CLIENTTYPE::OData,'') http://MyServer:7048/DynamicsNAV71/OData GETURL(CLIENTTYPE::OData,'NONEXISTING Corp') http://MyServer:7048/DynamicsNAV71/OData/Company('NONEXISTING Corp') GETURL(CLIENTTYPE::SOAP,COMPANYNAME) http://MyServer:7047/DynamicsNAV71/WS/CRONUS/Services GETURL(CLIENTTYPE::SOAP,'') http://MyServer:7047/DynamicsNAV71/WS/Services GETURL(CLIENTTYPE::SOAP,'NONEXISTING Corp') http://MyServer:7047/DynamicsNAV71/WS/NONEXISTING Corp/Services GETURL(CLIENTTYPE::Windows,COMPANYNAME,OBJECTTYPE::Table,27) dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/runtable?table=27 GETURL(CLIENTTYPE::Windows,COMPANYNAME,OBJECTTYPE::Page,27) dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/runpage?page=27 GETURL(CLIENTTYPE::Windows,COMPANYNAME,OBJECTTYPE::Report,6) dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/runreport?report=6 GETURL(CLIENTTYPE::Windows,COMPANYNAME,OBJECTTYPE::Codeunit,5065) dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/runcodeunit?codeunit=5065 GETURL(CLIENTTYPE::Windows,COMPANYNAME,OBJECTTYPE::Query,9150) dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/runquery?query=9150 GETURL(CLIENTTYPE::Windows,COMPANYNAME,OBJECTTYPE::XmlPort,5150) dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/runxmlport?xmlport=5150 GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::Page,27) ie. When the Web Service is published http://MyServer:7048/DynamicsNAV71/OData/Company('CRONUS')/PAG27Vendors GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::Query,9150) ie. When the Web Service is published http://MyServer:7048/DynamicsNAV71/OData/Company('CRONUS')/QUE9150MyCustomers GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::Page,27)Â ie. When the Web Service is published http://MyServer:7047/DynamicsNAV71/W...e/PAG27Vendors GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::Codeunit,5065) ie. When the Web Service is published http://MyServer:7047/DynamicsNAV71/W...65EmailLogging GETURL(CLIENTTYPE::Windows,COMPANYNAME,OBJECTTYPE::Page,27,record) List Page dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/runpage?page=27&bookmark=23;FwAAAAJ7/0kAQwAxADAAMwAw GETURL(CLIENTTYPE::Windows,COMPANYNAME,OBJECTTYPE::Page,26,record) Card Page dynamicsnav://MyServer:7046/DynamicsNAV71/CRONUS/runpage?page=26&bookmark=23;FwAAAAJ7/0kAQwAxADAAMwAw GETURL(CLIENTTYPE::Web,COMPANYNAME,OBJECTTYPE::Page,27,record) List Page https://navwebsrvr:443/DynamicsNAV71...kAQwAxADAAMwAw GETURL(CLIENTTYPE::Web,COMPANYNAME,OBJECTTYPE::Page,26,record) Card Page https://navwebsrvr:443/DynamicsNAV71...kAQwAxADAAMwAw GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::Page,27,record) http://MyServer:7048/DynamicsNAV71/OData/Company('CRONUS')/PAG27Vendors('IC1030') GETURL(CLIENTTYPE::Web,COMPANYNAME,OBJECTTYPE::Page,27) https://navwebsrvr:443/DynamicsNAV71...CRONUS&page=27 GETURL(CLIENTTYPE::Web,COMPANYNAME,OBJECTTYPE::Report,6) https://navwebsrvr:443/DynamicsNAV71...RONUS&report=6 If the GETURL function is called with invalid parameters, it will return an empty string. In that case, you can find the related error text by calling the GETLASTERRORTEXT function. Function Call Error Message GETURL(CLIENTTYPE::Web,COMPANYNAME,OBJECTTYPE::Table,27) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::Web,COMPANYNAME,OBJECTTYPE::Codeunit,5065) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::Web,COMPANYNAME,OBJECTTYPE::Query,9150) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::Web,COMPANYNAME,OBJECTTYPE::XmlPort,5150) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::Table,27) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::Page,27) The Page object, 27, that is specified for the GetUrl function has not been published in the Web Services table. GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::Report,6) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::Codeunit,5065) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::Query,9150) The Query object, 9150, that is specified for the GetUrl function has not been published in the Web Services table. GETURL(CLIENTTYPE::OData,COMPANYNAME,OBJECTTYPE::XmlPort,5150) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::Table,27) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::Page,27) The Page object, 27, that is specified for the GetUrl function has not been published in the Web Services table. GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::Report,6) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::Codeunit,5065) The Codeunit object, 5065, that is specified for the GetUrl function has not been published in the Web Services table. GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::Query,9150) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::XmlPort,5150) The specified object type parameter for the GetUrl function is not valid. GETURL(CLIENTTYPE::SOAP,COMPANYNAME,OBJECTTYPE::Page,27,record) You cannot specify a record parameter for the GetUrl function when the object type is SOAP NAV Usage Example The following example shows how to use the GETURL function in codeunit 440 to ensure that the notification mail in Document Approvals can link to both the Microsoft Dynamics NAV Windows client and the Microsoft Dynamics NAV web client: ![]() This resulting UI looks as follows. ![]() The first link opens the approval document in the Microsoft Dynamics NAV Windows client. The second link (Web view) opens the same document in the Microsoft Dynamics NAV web client. Best regards, Mike Borg Cardona, Bogdana Botez, and the Microsoft Dynamics NAV team Источник: http://feedproxy.google.com/~r/Micro...v-clients.aspx
