Старый 18.09.2013, 17:11   #1
25,751 / 851 (80) +++++++
kamalblogs: SSRS Tip: Using invisible parameters in contracts – Dynamics AX 2012
Источник: http://kamalblogs.wordpress.com/2013...amics-ax-2012/
There can be cases where you wanted a contract in the attribute but do not want the UI builder to expose it to the user. The reporting framework in AX provides a very easy way to incorporate this.
Open the parm method in the contract that you don’t want to expose. Add the attribute shown here along with other attributes. This attribute when found in the parm method will automatically prevent the UI builder from adding this to the dialog.
[DataMemberAttribute, SysOperationControlVisibilityAttribute(false)]public LogisticsAddressing parmAddress(LogisticsAddressing _address = companyAddress){ companyAddress = _address; return companyAddress;}This feature comes as a part of the BOF, see here http://j.mp/185ufd2
For more tips and learning about SSRS – AX 2012 order the book Dynamics AX 2012 Reporting Cookbook authored by me.
Related articles
Старый 19.09.2013, 11:09   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
SysOperationControlVisibilityAttribute(false) вроде не работает с отчетами
или у кого то получилось это использовать?
Парень написал книгу и не проверил что-ли
Последний раз редактировалось trud; 19.09.2013 в 11:12.
Старый 30.09.2013, 17:50   #3
casperkamal is offline
casperkamal
Thanks for pointing out trud. google helped me understand your comment. I realize what you say is right and i apologize for my mistake. I have posted an update here in my blog http://j.mp/1bm78za with the complete details of why it doesn't work that way.
Thanks Again
Kamal
За это сообщение автора поблагодарили: trud (3), Logger (3).
emeadaxsupport: Final Microsoft Dynamics AX 2012 R2 Content Available! Blog bot DAX Blogs 0 04.12.2012 06:12
dynamics-ax: Expert SSRS with AX Tip from Michael Stashwick Blog bot DAX Blogs 0 14.01.2011 05:18
Часовой пояс GMT +3, время: 20:38.
