Старый 24.11.2011, 11:05   #1
novic is offline
novic
Axapta Retail User
Axapta Retail User
168 / 25 (0) +++
Почему упал AOS
Как определить причину, почему упал AOS ?
DAX2009
Старый 24.11.2011, 11:18   #2
Zick-Zibn is offline
Zick-Zibn
Я бы в первую очередь посмотрел Журнал Windows\Приложение. наверняка туда что то попало.
Старый 24.11.2011, 11:26   #3
d&m is offline
d&m
MCT
Аватар для d&m
Manzana Group
459 / 186 (7) ++++++
Записей в блоге: 6
Сообщение от novic Посмотреть сообщение
DAX2009
сейчас общаюсь с англоязычной поддержкой Microsoft EMEA - и вот что они советуют по этому вопросу:
1) You could install the Debug Diagnostic Tools 1.2. This is a GUI tool that will set up a service to monitor the AOS. If the AOS crashes, it will dump all the application memory into a file and we can review this. I will add details on how to install and configure it below.
2) Another way would be to configure the built-in Windows Error Reporting (WER) to monitor the AOS. Please be aware that WER is only available in Windows Server 2008 (R2).
далее еще была доп инфа про WER (иначе его информативность близка к нулю):
You are right, that the standard WER messages do not supply enough info. But we have the option to set a new registry key which will cause WER to specifically monitor the AOS service and create a crash memory dump file (like DD 1.2 would) in case that the AOS service stops with an error.
For this you will have to create a registry key and then restart the whole machine, though. That is the reason why I would prefer to use DD 1.2 instead.
You can find info on this here:
http://blogs.msdn.com/b/emeadaxsupport/archive/2010/05/12/possibilities-to-create-memory-dumps-from-crashing-processes.aspx
How to configure WER to create a memory dump of a crashing AOS service:
You have to create the following registry key in order to monitor the AOS service:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Windows Error Reporting\LocalDumps\Ax32Serv.exe
In addtion to that you will have to define the following value keys below this registry key:
- DumpFolder (Define the patch where the dump files should be created, e.g. %LOCALAPPDATA%\CrashDumps)
- DumpCount (Should be configured to 3-5. Once the number of dumps in the DumpFolder location exceed this value, the oldest will be replaced)
- DumpType (Please configure to value 0. 0 = Custom dump, 1 = Mini dump, 2 = Full dump)
- CustomDumpFlags (If DumpType is configured to 0, please set this value to 7015 decimal or 0x1B67 hexadecimal)
Additional info on this can be found in the following MSDN article:
http://msdn.microsoft.com/en-us/library/bb787181(VS.85).aspx
За это сообщение автора поблагодарили: Bega (1).
Старый 24.11.2011, 12:17   #4
Bega is offline
Bega
Аватар для Bega
382 / 444 (15) +++++++
DAX2009
Проверьте в журнале приложения Windows, есть ли сообщения перед падением АОСа о том что отличается версия клиента. У нас это точно было причиной падения.
Последний раз редактировалось Bega; 24.11.2011 в 12:23.
Старый 24.11.2011, 12:25   #5
lev is offline
lev
Ищущий знания...
Аватар для lev
Oracle
Axapta Retail User
1,723 / 491 (20) +++++++
если АОС и БД на разных серверах, то так же в журнале приложений, перед падением АОСа посмотрите не запускается ли скан антивирусом, который отрубает на некоторое время сеть
сталкивался с этим не однократно...
С Уважением,
Елизаров Артем
Старый 24.11.2011, 16:04   #6
pedrozzz is offline
pedrozzz
Молодой, подающий надежды
Аватар для pedrozzz
164 / 218 (8) ++++++
DAX2009
Посмотрите по ссылкам, указанным в этом сообщении: единственный способ это исправить - зарегистрировать соответствующий запрос в поддержке
...опубликовал серию статей про анализ краш-дампов:
Setting up WinDbg and Using Symbols
Finding the AX user that caused an AOS crash (axforum)
Finding the X++ call stack that caused a crash (axforum)
Finding the AX user and the X++ call stack from a memory dump the easy way
So your AOS crashed, is hanging, or you just want to see what it's doing
добавлено emeadaxsupport: What to do if you have a crash
После этого краш-дампы стало возможным анализировать самому - без поддержки...
Последний раз редактировалось pedrozzz; 24.11.2011 в 16:07.
AX 2009: зачем нужен балансировщик нагрузки, и как в кластере зайти на определенный AOS? gl00mie DAX: Администрирование 7 26.02.2015 16:38
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
Часовой пояс GMT +3, время: 00:04.
