What am I trying to do here .. well, I'm working on three examples on how to call stored procedures, and where it could be useful for. The first blog article was about the first example, and also explained some basics. Therefore I strongly recommend to read that one, before you continue on this article. These will be the examples that I will be talking about:
Enough bla-bla, let's boom-boom! My SP looks something like this (I added some comments to make things clearer): ALTER PROCEDURE [dbo].[SP_LoadInventory] @ItemNo AS VARCHAR(20) AS BEGIN SET NOCOUNT ON; DECLARE @CompanyName VARCHAR(30) DECLARE @OrigCompanyName VARCHAR(30) DECLARE @SQLString NVARCHAR(MAX) DECLARE @Counter INT DECLARE curCompany CURSOR FOR SELECT [Name] as CompanyName from dbo.Company OPEN curCompany SET @Counter = 0 SET @SQLString='' FETCH NEXT FROM curCompany INTO @CompanyName -- Begin looping all companies in the database WHILE @@FETCH_STATUS = 0 BEGIN -- Converting the wonderful NAV-supported-but-best-not-used-in-SQL characters SET @OrigCompanyName = @CompanyName SET @CompanyName = REPLACE(@CompanyName,'.','_'); SET @CompanyName = REPLACE(@CompanyName,'"','_'); SET @CompanyName = REPLACE(@CompanyName,'','_'); SET @CompanyName = REPLACE(@CompanyName,'/','_'); SET @CompanyName = REPLACE(@CompanyName,'''','_'); -- Only put the UNION in between of two SELECT statements IF @Counter > 0 BEGIN SET @SQLString = @SQLString + 'UNION' END SET @SQLString = @SQLString + ' SELECT DISTINCT ''' + @OrigCompanyName + ''' AS CompanyName,ItemNo, LocationCode, LocationName FROM dbo.[' + @CompanyName + '$SP_ItemLocation] a WHERE ItemNo = ''' + @ItemNo + ''' ' FETCH NEXT FROM curCompany INTO @CompanyName SET @Counter = @Counter + 1 END; print @SQLString -- to make it easier to debug EXEC sp_executesql@SQLString CLOSE curCompany DEALLOCATE curCompany END As you can see, it's going to UNION the results I'm getting from the SELECTs on the Company-specific views I created in my previous post. This for all companies, no matter how many companies I have in my database.. . Quite generic, no configuration required. Thank you SQL Server! As this SP is going to give us a table, we're going to try to present that table in a page, with this code ... <Open your connection here> SQLCommand := SQLCommand.SqlCommand(); //Constructor SQLCommand.CommandText := 'SP_LoadInventory'; SQLCommand.Connection := SQLConnection; SQLCommand.CommandType := GetEnum(SQLCommand.CommandType,'StoredProcedure'); SQLCommand.CommandTimeout := 0; SQLParameter := SQLParameter.SqlParameter; SQLParameter.ParameterName := '@ItemNo'; //Name of the parameter SQLParameter.SqlDbType := GetEnum(SQLParameter.SqlDbType,'VarChar'); SQLParameter.Direction := GetEnum(SQLParameter.Direction,'Input'); SQLParameter.Size := 20; //20 characters SQLParameter.Value:=ItemNoVariable; SQLCommand.Parameters.Add(SQLParameter); SQLReader := SQLCommand.ExecuteReader; WHILE SQLReader.Read DO BEGIN GlobalInventoryBuffer.INIT; GlobalInventoryBuffer."Item No." := SQLReader.Item('ItemNo'); GlobalInventoryBuffer."Company Name" := SQLReader.Item('CompanyName'); GlobalInventoryBuffer."Location Code" := SQLReader.Item('LocationCode'); GlobalInventoryBuffer."Location Name" := SQLReader.Item('LocationName'); GlobalInventoryBuffer.INSERT; END; PAGE.RUN(PAGE::"Global Inventory Overview", GlobalInventoryBuffer); ... <Close your connection here> This is quite a difference with the ADO automation version, isn't it? Well, it makes sense to use the datareader (as that's all we want to do here). It gives us a clean an nice way to read our resultset. The SQL Reader is a DotNet variable of: 'System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Data.SqlClient.SqlDataReader That's all for example 2. I don't state this example is a "useful" example, but it shows you can combine the "power of SQL Server " (views, any SELECT statement, ...) with NAV quite easily. And now you can do it by using the .Net framework! Читать дальше
